Message |
The power supply lead for the vtc, wategates etc, which on my 93 is a black wire with red stripe, runs to a 10amp fuse and that is fed by what appears to be ignition switch and a controller module. I understand the concept but with the battery unplugged and the ecu unplugged the circuit has continuity with ground. If I test from the supply side for the 10amp fuse it gives me continuity with ground. So I'm wondering if while the ignition switch is off this +lead is grounding out or something of that sort?
"torque gets you off the line...& hp gets you over the line." - TTKeeper |
